Does a Technicolor TG582n FTTC router work on a simple ads like service?
ajam
Today my Sky service moved to plus net. I bought a Technicolor TG582n FTTC and plugged it in but my adsl broadband service doesn't have a green light.  I can reinstate the sky router and it still works so I wonder if I bought the wrong router, or should it work on adsl?  Thanks in advance. (ps fibre isn't an option for me)
8 REPLIES 8
Anoush
Aspiring Hero
Fixes: 139
Re: Does a Technicolor TG582n FTTC router work on a simple ads like service?
Hello there. The technicolor TG582n routers aren't interchangeable between ADSL and FTTC. They're either one or the other, I'm afraid.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
ejs
Aspiring Hero
Fixes: 25
If the Technicolor 582n is running the 10.2.5.2 firmware, it can easily be switched between FTTC and ADSL modes.
ajam
MANY THANKS for a clear and current answer.
I am running V8 so I need to upgrade. The router has a USB and is FTTC but I need to switch to ADSL. Does it matter which one of these I choose please EO or FO?
Plusnet - ADSL - TG582n-PS (without USB port) - 10.2.2.B <=== I have a USB port, so no?
Plusnet - FTTC - TG582n (with USB port) - 8.C.M.0 <== What it appears to be using now?
Plusnet - FTTC - TG582n (with USB port) - 10.2.5.2.EO <==== ?
Plusnet - FTTC - TG582n (with USB port) - 10.2.5.2.FO<==== ?
Product Name: TG582n
Serial Number: CP1233xxx11
Software Release: 8.C.M.0
Software Variant: DG
Boot Loader Version: 1.0.5
Product Code: 3684778B
Board Name: DANT-T
MatthewWheeler
Fixes: 479
You can just pick the ADSL version and that should do the trick.
 Matthew Wheeler
ajam
MatthewWheeler
Fixes: 479
Nope it's this one
Unless you want to use the USB port either of the two Fibre ones will work but the ADSL one has the least amount of messing around.
 Matthew Wheeler
ejs
Aspiring Hero
Fixes: 25
Someone else mentioned that when using a non-USB firmware on a model with a USB port, it somehow did not work properly.
10.2.5.2 FO is the latest version and I think is what many people were remotely upgraded to, however it does a bug where the 4th LAN port does not work when switched to ADSL mode. EO does not have that bug.
Anotherone
Champion
Fixes: 21
Do NOT use the 10.2.2.B firmware on the USB model it has a multitude of issues too complicated to remember and explain (and it was a while ago when I tested).
In view of the issue raised by ejs, use the 10.2.5.2.EO version, that works OK.
