Does BT Smart Hub 2 FTTP work on FTTC too?
kankali
Looking to buy on of these to use on Plusnet FTTC and wondered if the FTTP variant also works on FTTC?
7 REPLIES 7
dave501
Fixes: 6
Re: Does BT Smart Hub 2 FTTP work on FTTC too?
kankali
@dave501 Thanks,
Wonder why then BT go to the trouble of producing 2 versions!
dave501
Fixes: 6
@kankali maybe different manufactures, Sagemcom make the smarthub 6A whereas Arcadyan make the smarthub 6B both do the same job but use different chipsets
Fixes: 49
Are we talking about the HomeHub 6 or the newer SmartHub 2? I gather there's also a busness version.
Both work on PlusNet as far as I'm aware.
kankali
@bmc The newest one, Smart Hub 2
bobpullen
Fixes: 316
@kankali wrote:
@dave501 Thanks,
The FTTP version repurposes one of the LAN ports as an ETHWAN port as far as I know, so basically you lose a LAN port with the FTTP version.
kankali
I just picked up an FTTP Smart Hub 2, and I can confirm it also works with VDSL FTTC ........and no issues with the using it on Plusnet.
