Does BT Smart Hub 2 FTTP work on FTTC too?
FIXED- Subscribe to RSS Feed
- My Router
- Does BT Smart Hub 2 FTTP work on FTTC too?
07-02-2020 3:59 PM
Looking to buy on of these to use on Plusnet FTTC and wondered if the FTTP variant also works on FTTC?
Fixed! Go to the fix.
08-02-2020 5:09 PM
Seems it does according to this thread https://community.bt.com/t5/Home-setup-Wi-Fi-network/Can-I-use-this-Smart-Hub-2-with-fibre/td-p/1984...
Re: Does BT Smart Hub 2 FTTP work on FTTC too?
08-02-2020 6:18 PM
08-02-2020 8:09 PM - edited 08-02-2020 8:11 PM
@kankali maybe different manufactures, Sagemcom make the smarthub 6A whereas Arcadyan make the smarthub 6B both do the same job but use different chipsets
08-02-2020 8:34 PM
Are we talking about the HomeHub 6 or the newer SmartHub 2? I gather there's also a busness version.
Both work on PlusNet as far as I'm aware.
09-02-2020 8:57 AM
@bmc The newest one, Smart Hub 2
12-02-2020 10:52 PM
@kankali wrote:
@dave501 Thanks,
Wonder why then BT go to the trouble of producing 2 versions!
The FTTP version repurposes one of the LAN ports as an ETHWAN port as far as I know, so basically you lose a LAN port with the FTTP version.
16-02-2020 9:43 PM
I just picked up an FTTP Smart Hub 2, and I can confirm it also works with VDSL FTTC ........and no issues with the using it on Plusnet.
- My Router
