Do PlusNet supply a VDSL modem instead of a Hub One router?
- My Router
- Do PlusNet supply a VDSL modem instead of a Hub On...
06-11-2018 4:54 PM
Title says it all really. Having so many problems with the HubOnes on my connection, particularly on the latest firmware, if I decide to renew my contract can PN supply just a VDSL modem only solution instead of a HubOne router so I can put a decent router for Wifi access in the home?
thx
Dave
Re: Do PlusNet supply a VDSL modem instead of a Hub One router?
06-11-2018 5:33 PM
No. Plusnet will only supply the Hub One.
You are better off buying your own equipment. Then you have a choice over all the parts.
06-11-2018 7:13 PM
Wot he said.
08-11-2018 10:02 AM - edited 08-11-2018 10:13 AM
Get a Huawei HG612 Model 3B off Ebay for around £10. These work very well and can be easily unlocked to get full stats. See https://kitz.co.uk/routers/hg612unlock.htm
Alternatively keep the Hub One, turn off the wireless on it and buy either a Wireless Access Point or a router that can be configured as a WAP.
Edit. One final thought, you could always spend £20-39 again on Ebay ang get a BT Smarthub 6. A lot of us use them on our Plusnet account and find them to be trouble free and have excellent wireless coverage.
08-11-2018 12:50 PM
Don't know where you are, but if anywhere near the SG19 1 postcode area, I have one you can have. Not willing to post though as it hasn't been used for several years and whilst working when removed, no guarantees now.
Mark
09-11-2018 9:06 AM
Mark,
Offer is much appreciated but I'm quite a way from you.
cheers
dAve
- My Router
