Display wired connections in router
GaryWilliams1
How do you get the plusnet router to display the wired connections, Lan2 to Lan4?  Except for my main PC in Lan1, the rest appear blank.
3 REPLIES 3
southerner
Re: Display wired connections in router
Which screen are you checking?
For me 'Home' shows all my devices but 'Advanced/Home Network/Devices' only shows devices currently active.
GaryWilliams1
Hi Woodm,
The wired display is the same on both of those pages.  Perhaps I have a duff router?
moansalot13
hi - a hub reset worked for me - I was having similar issue - poke a paperclip into reset port on back and hold it in until front light cycles though and remains stable.
post reset it picked up connections on the other lan ports  - hope this helps
credits go to another user/forum member  - apologies forgotten who.
