Display wired connections in router
- My Router
- Re: Display wired connections in router
07-09-2016 3:06 PM
How do you get the plusnet router to display the wired connections, Lan2 to Lan4? Except for my main PC in Lan1, the rest appear blank.
08-09-2016 12:59 PM
Which screen are you checking?
For me 'Home' shows all my devices but 'Advanced/Home Network/Devices' only shows devices currently active.
08-09-2016 2:49 PM
Hi Woodm,
The wired display is the same on both of those pages. Perhaps I have a duff router?
21-10-2016 2:29 PM
hi - a hub reset worked for me - I was having similar issue - poke a paperclip into reset port on back and hold it in until front light cycles though and remains stable.
post reset it picked up connections on the other lan ports - hope this helps
credits go to another user/forum member - apologies forgotten who.
- My Router
