Disabled firewall (Plusnet Hub One) still blocking traffic
- My Router
- Disabled firewall (Plusnet Hub One) still blocking...
21-02-2020 9:27 AM
To helping debugging a port forwarding issue, I disabled the firewall entirely.
Got the message "Changes made" or similar.
Traffic is still blocked.
I am using https://www.yougetsignal.com/tools/open-ports/ to test which ports are open
The effect of disabling the firewall is clear => "Allows all traffic to pass through the Firewall.".
Restarting makes no difference.
What is the fix please, I need the firewall to work as it should!
Message 1 of 3
(540 Views)
2 REPLIES 2
Re: Disabled firewall (Plusnet Hub One) still blocking traffic
21-02-2020 9:51 AM
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Message 2 of 3
(531 Views)
21-02-2020 9:54 AM
Port forwarding does work with the Hub 1 a little more detail may help assist.
i.e. what ports are you trying to forward, have you tried connecting to the app whilst on the lan etc.
Message 3 of 3
(529 Views)
- My Router
