Disable dsl
Jovin123
Disable dsl
Hi All
I'm using a Hub One as a wifi extender (DHCP off & ip set outside of range of main router) however it is constantly searching for a DSL connection. Is there anyway to disable this?
TIA
1 REPLY 1
HarryB
Fixes: 256
Re: Disable dsl
Hi @Jovin123, I don't believe that's possible unfortunately
 Harry Beesley
