Differential speed on laptop purchased from Dubai
abhineetk
Hello, I have a Fibre 500MB connection, and it gives good speed on a few mobile and laptop devices at home.
Surprisingly, I get extremely slow speed on my HP Windows 11 laptop purchased from Dubai, which was working fine over there but I'm not sure whats the issue when it connects with Plusnet WIFI. Tried to change bands through online configuration link but nothing is working and even the drivers are updated in my laptop which supports both 2.4 and 5 GHz
Can anyone suggest what to do? Do I need to change the Hub 2 modem provided by plusnet?
Thanks a ton in advance
22 REPLIES 22
Fixes: 369
Re: Differential speed on laptop purchased from Dubai
I may be wildly off the mark here - and I'm sure someone will correct me - but I suspect the machine purgased i Dubai, rather than anything to do with your router, is the culprit here.
Fixes: 567
@abhineetk is the laptop connecting to the 5ghz band ? You should be able to see from the Hub2 devices page
What model is the Wireless NIC in the laptop ?
Fixes: 369
Following from @MisterW , above, what speeds do you get when connecting the laptop to the Hub by Ethernet?
Fixes: 471
Moderator's note:
Thread moved from Full Fibre to My Router
Fixes: 369
@Baldrick1 I think this would be better Tech Help if you want to move it somewhere useful - it is not the Hub that is at fault.
abhineetk
This laptop was working fine for around 2 years in Dubai on similar broadband fibre connection but causing issue in the UK network, looks some software driver changes required but not sure
Fixes: 369
@abhineetk Answers to @MisterW 's and my follow-up posts would be helpful.
abhineetk
@MisterW It shows connected to 2.4 GHz via WIFI and speed is <10 MBPS
If connecting via Ethernet Cable then it is giving good speed >200 MBPS
Other details mentioned below for refernece:
MAC address:
F8:89:D2:20:72:29
Connection type:
Wireless
Address assignment:
DHCP
Wireless Option
Dual band: No
Fixes: 369
@abhineetk Tat response to @MisterW doesn't answer his question, and if you are supposedly on a 500Mb connection, 200mb/s on a wired connection suggests, as I said above, the issue is your machine.
abhineetk
Sometimes it automatically connect with 5 GHz then speed is comparatively higher like >50 MBPS but then again connects to 2.4 GHz giving much slow <10 MBPS speed
Fixes: 567
@abhineetk
Well that's the first problem, understanding why its not connecting to the 5ghz band.
Check the 'Preferred band' setting in the Advanced properties of the Wireless NIC. Make sure its set to 'prefer 5ghz'
abhineetk
@jab1 I mentioned this is a new machine and working perfectly fine in other regions giving more than 1 GBPS speed consistently, it looks more of software configuration. Might be possible that a new modem or router with better dual band configuration might help.
Fixes: 567
The Hub 2 is perfectly capable of delivering  1Gb on a wired connection and up to around 450Mb on a wireless connection on the 5ghz band
Fixes: 369
This 2 year old machine is probably designed for use in Dubai and similar regions - which are not the same as the UK.
