Devices won’t stay connected.
Adamyeo1
Hi, my broadband is working fine, but for the last few days devices won’t stay connected to tel he router by WiFi and the log in passwords are rejected repeatedly.
4 REPLIES 4
Fixes: 384
Re: Devices won’t stay connected.
@Adamyeo1 Which router are you using - Hub0 or hub1?
Login passwords for what?
LaurenB
Fixes: 131
Hiya @Adamyeo1, I am really sorry for the issues being experienced with your WiFi.
I have amended some settings in your router remotely, so that your wireless frequencies are now split. In your devices WiFi settings you should now see 2 available connections (if the device is compatible), with one ending in -5G.
Can you see if you experience the password issue with both frequencies and let us know how you get on.
 Lauren Barry
Strat
Fixes: 565
Moderators Note
This topic has been moved from ADSL Broadband to My Router.
Adamyeo1
Thank you! That seems to have done the trick!
