Devices keep losing WiFi connection
- My Router
- Devices keep losing WiFi connection
13-07-2019 6:42 PM - edited 13-07-2019 6:43 PM
Re: Devices keep losing WiFi connection
13-07-2019 8:24 PM
Thanks for getting in touch @jaynefennec
We've tested your line and we can't see any issues remotely.
When you next lose connection can you try logging into your router by going to http://192.168.1.254? This will allow us to see if you're losing connection to the router or the internet itself
19-07-2019 10:38 PM
Hi Jaynefennec
I suggest you have a look at the posts in topics
to see if you think your problem is similar to others' in these discussions. If you can see that the devices that are losing Wifi were connected to the 5GHz stream, then it may be. What others are finding frustrating is Plusnet's apparent unwillingness to tell people with this problem that they are part of a significant group. They seem to prefer to try to keep us isolated and thinking our problem is rare or unique and hence may be our "fault" not theirs, whereas the cause of our problem (and maybe yours?) is that the latest Hub One firmware release 4-7-5-1-83-8-263 apparently has a fault in it causing 5GHz to fail repeatedly.
I hope your problem is something else, and more easily fixed!
Regards
ttstoo
- My Router
