Device names in Plusnet Hub One Manager
SarahT
Hi Does anyone know if its possible to rename a device in the Hub Manager? My problem is my son and husband both have the same phone and when I try to restrict my son's phone's access it blocks my husbands too because both phones have the same name.
Thank you
5 REPLIES 5
Fixes: 1,466
Re: Device names in Plusnet Hub One Manager
Moderators Note.
Moved to 'my router' from the fibre board.
Seasoned Champion
Fixes: 49
Hello,
It maybe easier to rename the phone,
Samsung Android phone take a look in 'Settings >About phone >Device name'
iPhone 'Settings >General >About >Name'
Hope this helps
Dan.
Fixes: 1,466
It can be done in the router, though the above suggestion is perhaps a better one.
Under 'advanced settings > home network > devices
click a phone and then you'll see 'Network Name' which you can change.
SarahT
Thank you. This has worked well.
SarahT
Thank you. Did use the mobile naming suggestion, but useful to know there is another way too.
