Design flaw in the Hub Two
daveheee
Re: Design flaw in the Hub Two
True, but then I could sign up to sky and pay a third less if I was going to use my own ...also I'd have to fork out for it too ... obviously.
rbz5416
On that, Sky's routers don't support it either & your choice of third party routers would be very limited due to their authentication method.
spile
pint
Cover the lights if its disturbing you, talk about EMF issues is complete and utter nonsense believed by fools, alternatively wear a tin foil hat and wear a magic stone
daveheee
That's a good point ... probably going to have to go back to Vodafone Sad
daveheee
@pint ...it's only nonsense unless it affects you. Plus companies and government never give out false info about anything do they. The tin foil hat comment is just a cheap insult that brainwashed morons resort to when they hit an intellectual wall.
daveheee
Thanks for the help but I can control what the kids can access using the Hub Two ...maybe you missed the point.
craigski
Thanks for raising this important topic Davehee.  The 'normies' are not quite on our wavelength eh?
I do the switching on and off manually.  It is a pain as you rightly say.
I would like to automate it with a more 'feature rich' router  What is the best one that will work with Plusnet?
BTW, are you up to speed on the smart meters, LED light & 5G?  I met a chap called Mark Steele (not the comedian) who has looked at these in-depth and from an electrical engineering background perspective.
All the best.
