Dead Spots in my House
measha06
Originally I was with BT who supplied discs through my small bungalow to ensure no dead spots as apparently I have dense walls. I have moved to Plusnet and have a Hub 2 and considering converting to a mesh system to work as BT discs did. Ive tried pairing BT discs to Hub 2 but this doesnt work. Does anybody have any recommendations as to how to proceed I am really non techy in this area and just want best signal I can all over the house
1 REPLY 1
Fixes: 480
Re: Dead Spots in my House
@measha06  Welcome to the Community forums.
Whilst they look the same the BT and Plusnet hubs have different firmware. The Plusnet hub will not work with satellites. If you still have the BT hub then you can use this. The setting instructions are pinned to the top of this board.
