Danger of blue light on router
Rhino
There have been many comments on the blue light being too bright. However, much more important is the fact that it is harmful to one's health. This is especially true coming up to bedtime when it will disrupt the body's ability to produce melatonin, the sleep hormone.
6 REPLIES 6
bobpullen
Fixes: 330
Re: Danger of blue light on router
Our newer hub (offered with Fibre/Full Fibre products) comes with the ability to either dim, switch off or schedule the LED to switch off at a desired time.
Unfortunately this isn't the case with the Hub One that I believe you currently have. A dirty solution would be to cover it with some electrical tape or similar.
Fixes: 382
@bobpullen I was just going to advise the 'tape' route!😃
HPsauce
All Star
Fixes: 5
Hub one does have a dim option, though it's still quite bright in the dark of night.
Ours is near our front door and I find it's a useful "night light".
Before bedtime, with other lights on, it's relatively dim so I can't think it has any real "blue light" effect.
Mav
Fixes: 518
Moderator's note(s):
Thread moved from Broadband to My Router.
Forum Moderator and Customer
Rhino
What is the purpose of what looks like a flap under the blue light?
bobpullen
Fixes: 330
@Rhino - there are LED's behind it that illuminate in certain notification/error conditions e.g. if Wi-Fi is disabled or there's no broadband signal being detected.
