DSL Sync Speed Different Modem/Routers
- My Router
- Re: DSL Sync Speed Different Modem/Routers
08-02-2020 9:45 AM
Any thoughts?
09-02-2020 11:09 AM
This topic has been moved from ADSL Broadband to My Router.
09-02-2020 12:12 PM
Although I do not know why....
On my Draytek Vigor 2862 modem/router I get an actual sync down rate of 67.6 Mbps and max Attainable Rate 67.7 Mbps
Whereas, on 3 others,a ZyXel, a New TP-Link and a vodafone (Huawei) they all sync about 3 mbps lower at around an actual 64.6 and max attainable 65.7.
Running speed tests on all of them, the throughput down is always a bit lower than the sync down rate.
For example 63 / 64 mbps on the Draytek and 60 / 61 on the other three.
09-02-2020 2:19 PM
12-02-2020 8:50 PM
> I think you can just check with your Internet Service Provider about the line status.
> The DSL line status depends on the connection with the ISP's server.
> You can also check the problem another day reboot the Modem to see the negotiation DSL speed.
> It will change every time building the DSL connection with ISP's server.
Should the sync speed change through rebooting the router?
12-02-2020 10:13 PM
In my case no, It's almost identicle to within 0.1 Mbps compared to the previous time I connected the same modem /router.
However, if swap one modem / router for another, I always switch the running modem off first and wait just over 35 to 40 minutes before powering up the next modem / router.
I've read it's best to do this, aparently because after 30 minutes the current session will end and the DLM will treat it as a power cut and exclude those two 15 minute intervals as not being a connection issue. Something along those lines anyway.
In my case though it's fast path (no interleave), INP an G.IMP are not enabled on my street cabinet. I don't know if any of these were enabled if that could make it different or not.
The only execption i've had once, was when the max attainable rate fell below the actual rate. Then when I did a reboot, the actual rate fell to just slightly below the max rate.
Maybe some other people have experienced different this if they have INP or G.IMP enabled, although I can't recall anyone saying anything about this.
- My Router
