DSL-AC88U connection problems
- My Router
- DSL-AC88U connection problems
26-03-2019 1:03 PM
After much frustration, and after reconnecting my old Plusnet modem and router, I had exactly the same issue with the old router/modem combo.
The agent I spoke to could see my Asus router authenticating but not connecting, and when I swapped the routers over and reauthenitcated my credentials using that, he could only see the Asus router still attempting to ‘start’ and no sign of the Plusnet router at all.
I’d had the usual “your router must be faulty” and I’d downloaded and installed the firmware update for the Asus Rueter from the Asus website, but nothing worked.
I spoke to an IT friend of mine, who suggested that the evidence pointed to a problem with the Mac Address filtering cache at Plusnet’s end.
The solution, for me at least, was simply to switch everything off and unplug all from the phone socket and leave them for two hours minimum. This allowed the Plusnet cache of my MAC address to clear, and when I reconnected the Asus router and went through authentication again, it worked first time!
No settings to fiddle with, no manual input of any information, just a smart new router that I’m very impressed with.
Hope this helps someone looking for it.
The solution appears just to be patience...
Re: DSL-AC88U connection problems
30-03-2019 4:18 AM
Thanks for your post. Glad to hear your new router seems to be working well.
I can advise though that we don't actually use your MAC address in any way. You can authenticate to us using any MAC address. Proving the credentials are accurate, that's all that's required.
04-04-2019 4:44 PM
I have had issues with both Asus RT-N66U and RT-AC68U where the internet wouldn't connect and was unable to reach the Asus interface via 192.168.1.1 in my web browser.
It turned out it was a device on my wired LAN causing problems - once that device was unplugged everything worked again.
- My Router
