DNS Issues
IanSudbery
Re: DNS Issues
Oops, sorry. I was connected to my office VPN and didn't notice. Should be fixed now.
bobpullen
Fixes: 316
Re: DNS Issues
@IanSudbery - thanks.
I've pushed what is hopefully a full firmware fix to your device. It will have rebooted yesterday to apply the change.
Please keep an eye on it and let me know at the first sign of a recurrence - although I'm hoping there won't be one!
Thanks again for your help in getting to the bottom of things 👍
HKafemanPC
Re: DNS Issues
@bobpullen
Bob
FYI - I have had the DNS lookup issue again last week and yesterday! - I restarted the Hub One using the button to resolve.
I have been on .273 firmware since 17th August. So this issue seems to be more prevalent with .273 than it was with .263 as that went for many months without the issue being apparent!
Henry Kafeman
bobpullen
Fixes: 316
Re: DNS Issues
@HKafemanPC I can push the same build to your device if you're willing to give it a go but I can't guarantee that it won't re-introduce the Wi-Fi issues that led to you requesting the .273 update. Now that I think we know the cause of the DNS issue, there's no logical reason why it would be any worse on .273 compared to earlier builds. If anybody is homeworking and using a VPN, then that can exacerbate the issue. Let me know what you'd like to do.
@IanSudbery - Am I safe to assume there hasn't been another occurrence of the issue in the last week or so?
IanSudbery
Re: DNS Issues
@bobpullen We had an incidence the same day that you informed us the update had been installed the day before, but I'm going to put that down the router having not restarted since the update. Since then its been plain sailing, so I guess I'll mark this as fixed.
bobpullen
Fixes: 316
Re: DNS Issues
Hmm, I'm sure I remember restarting it - so continue to keep an eye on things and let me know at the first sign of problems. We've definitely resolved one of the conditions leading to this issue by the looks of things. That's not to say there aren't more though.
bobpullen
Fixes: 316
Re: DNS Issues
Everything still good @IanSudbery?
IanSudbery
Re: DNS Issues
Yep, no issues on the DNS front as yet.
We have had a few connection drops, but I'm going to assume for the moment that these are unrelated.
rob_bob
Re: DNS Issues
@bobpullen I am also experiencing similar dns issues, if I set a static dns server (google's 8.8.8.8) then my laptop starts working again but all the other devices in the house still don't have internet access (although they are still connected to the wifi). Is it possible to get the firmware update installed on my router too?
bobpullen
Fixes: 316
Re: DNS Issues
@rob_bob - I've pushed an update to your router. You'll need to reboot to apply it.
tonygould
Re: DNS Issues
@bobpullen I've been seeing DNS issues for some time. It's really really frustrating. Same MO -- if I change to google DNS devices are unaffected, switching the router off and on fixes the problem, etc. Can you help?
bobpullen
Fixes: 316
Re: DNS Issues
@tonygould - I can't see a Hub One associated with your account. If you're using one, then would you mind private messaging me your device serial number, MAC address and account username please?
tonygould
Re: DNS Issues
hi @bobpullen, thanks for replying. I'm not sure I have a hub one. I've just got whatever standard router I was issued with,Technicolor TG582n FTTC. We've been experiencing these DNS issues for a very long time -- this week it's particularly bad (some other weeks it hasn't been such a problem). This thread seems to indicate that you understand the source of the DNS problem. Is it something related to the plus net network? Or can I fix it at my end?
bobpullen
Fixes: 316
Re: DNS Issues
The issue being discussed here is due to a fairly uncommon combination of events that occur with particular DNS responses and the way the Hub One handles them. It's therefore not relevant to your case.
If you think it will help, the DNS servers assigned to your router can be changed. It involves a degree of technical capability though as you'll need to make the changes using telnet.
tonygould
Re: DNS Issues
Ah, ok. TBH, I don't know whether or not it would help -- the reason I went on to this thread was because I came across someone who seemed to understand the technicalities. Are you suggesting it's possible to change the DNS on the router to google's servers, or to some other alternative? Given that google's DNS servers continue to work when the DNS issue happens, that could be worth a shot.
I've been a happy plus net customer since 2001, but this problem has been happening for a year or three (maybe since I upgraded to fibre?) and it's getting to be a real issue for us. I put up with the frequent complaints from family members and having to reset the router because I thought that it would be  unlikely to get hold of someone who understood the problem.
I'm happy to try telnet. I'm very comfortable using linux command line (and cmd on windows when I have to). I normally run ubuntu 18.04 at home (where telnet is already installed), only going into Windows to run netflix / games.
The other thing I don't understand is, should I really have a Hub One rather than the modem / route combination I have? Given I'm on unlimited fibre.
