DNS Issue?
- My Router
- DNS Issue?
- « Previous
- 1
- 2
- Next »
Re: DNS Issue?
04-06-2021 2:29 PM
Issue just occurred again and I ran another ipconfig report. Here's the results:
Windows IP Configuration
Host Name . . . . . . . . . . . . : JEROMMIL-3C84M
Primary Dns Suffix . . . . . . . : cisco.com
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : cisco.com
lan
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Cisco AnyConnect Secure Mobility Client Virtual Miniport Adapter for Windows x64
Physical Address. . . . . . . . . : 00-05-9A-3C-7A-00
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (6) I219-LM
Physical Address. . . . . . . . . : 98-FA-9B-C5-60-A0
DHCP Enabled. . . . . . . . . . . : Yes
Wireless LAN adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 04-ED-33-41-A5-AB
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Intel(R) Wireless-AC 9560 160MHz
Physical Address. . . . . . . . . : 04-ED-33-41-A5-AA
Link-local IPv6 Address . . . . . : fe80::41a1:d3d2:d017:92e4%15(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.74(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 04 June 2021 13:49:59
Lease Expires . . . . . . . . . . : 05 June 2021 13:49:58
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 251981107
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-52-A5-26-98-FA-9B-C5-60-A0
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 04-ED-33-41-A5-AE
Re the DHCP lease being long, I did have this set at 21 days as I saw this recommended in another thread. Now the router has been factory reset it's back to 1 day.
I also did some 'nslookup' tests and whilst none of the requests timed out, this came up:
nslookup bbc.co.uk
*** Default servers are not available
Server: UnKnown
Address: 127.0.0.1
Re: DNS Issue?
04-06-2021 2:36 PM
@Jherhome1 did that nslookup complete and return an IP ?
Did all the other nslookups complete ?
Re: DNS Issue?
04-06-2021 2:56 PM
@MisterW that one didn't complete and return an IP address. It does now though that I've restarted the router.
The other nslookups returned this, which I assume means they completed:
Non-authoritative answer:
Addresses: 2a04:4e42::81
2a04:4e42:200::81
2a04:4e42:400::81
2a04:4e42:600::81
151.101.0.81
151.101.64.81
151.101.128.81
151.101.192.81
Re: DNS Issue?
04-06-2021 3:28 PM
The ipconfig reports look odd to me - but might be a red herring?
IPv4 Address. . . . . . . . . . . : 192.168.1.64(Preferred)
Lease Obtained. . . . . . . . . . : 03 June 2021 21:33:40
Lease Expires . . . . . . . . . . : 25 June 2021 08:59:53
I believe (which means I might be mistaken) that if "(preferred)" is attached to an IP address it means that the address is static in the DHCP service.
Therefore it seems odd that the device should have two different "preferred" addresses ... and I note that the DHCP lease period is now 24 hours, not 22 days.
Re: DNS Issue?
04-06-2021 5:02 PM
that does indicate the problem is with the routers internal dns server
I'd suggest adding a post in this thread https://community.plus.net/t5/My-Router/DNS-Issues/td-p/1745510/page/8 and asking Bob for the trial firmware
- « Previous
- 1
- 2
- Next »
