Connecting to router.
Roddyr01
I have several devices connected successfully to my router but my Galaxy Tab A will connect but after a few hours drops out and won't re-connect. Getting a message " connection not authenticated ".
Is this to do with way the router filters MAC addresses or? Any ideas?
5 REPLIES 5
wakeman
Re: Connecting to router.
@Roddyr01
Welcome to the forums.
Is your device using the 2.4 or 5 Ghz Wi-Fi ?  It could be it has dropped out of range with 5 Ghz.
Are you using a Hub One PlusNet router? If so you could login into it a separate out the 2.4 and 5Ghz Wi-Fi so they use different SSID's. Some people have found this helps with Wi-Fi issues.
Other possibilities are you are getting interference from other Wi-Fi users nearby, there is limited bandwidth and channels and everyone is fighting for the best.
Roddyr01
Thanks for that. Yes. Using Hub one. It automatically decides which GHz to use. How can I separate them and force it to use the 2.4 Ghz for this device. I dont have any issues with other devices.
Fixes: 1,474
Splitting:
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
Fixes: 1,474
Moderators Note
This topic has been moved from Fibre to My Router
Roddyr01
OK. Thanks. I've done that and am currently connected to the 2.4Ghz. It's now a matter of time to see if it stays connected.
I'll let you know.
Thanks.
