Connecting to a VDSL modem
geffers
Do any members on here use a VDSL modem for connection rather than a modem/router?
Reason I ask is I am investigation some network issues and have set my TP-Link TD-W9970 temporarily as a modem, status page says it is correctly set up and connected.
Problem is I cannot successfully connect an individual computer to it, has anyone used a PPPoE client or command line to connect?  If so would appreciate the settings, I'm suspecting it might have something to do with the VID of 101
Geffers
3 REPLIES 3
Fixes: 392
Re: Connecting to a VDSL modem
Have you set the 9970 to bridge mode ?
In bridge mode you should be able to connect to a lan port and make a pppoe connection
Theb9970 will handle the vlan id
Fixes: 417
@geffers
The settings are here. https://www.plus.net/help/broadband/broadband-connection-settings/
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Router
