Connecting new router to catch up tv
Josimarsz
Can anyone help? I received a new router from plusnet which has the new router password etc.  I have managed to set up my laptop and tablet. I would now like to set up my catch up TV and my kodi box. Does anyone know how? Please bear in mind I am not very computer literate! Thanks in advance! X
5 REPLIES 5
HairyMcbiker
All Star
Fixes: 21
Re: Connecting new router to catch up tv
If they are wifi enabled then connect them the same way as you did your tablet, if cable connected just make sure that DHCP is enabled on the ethernet interface.
Gel
Aspiring Champion
Fixes: 29
Josimarsz
Thank you x
Josimarsz
Thank you
Josimarsz
Thanks! I think I was having a total crazy episode! Makes sense and it is fixed! (Told you I was not computer literate! Roll_eyes)
