Connecting mobile phone to wifi
- My Router
- Connecting mobile phone to wifi
23-06-2018 4:53 PM
I have anew mobile phone, a Motorola G5, which will not connect to my wifi. Everything else works on the phone: internet access etc but it will not connect to my home wifi. I get 'authenticating' then, after a couple of minutes 'authentical problems' message appears. I have just checked and connected to a friend's wifi and that went in after just a few seconds.
Any ideas, anyone?
Thanks in anticipation
Ray
Re: Connecting mobile phone to wifi
23-06-2018 8:32 PM
Sounds like you've entered the WiFi password incorrectly. Try the '''forget network" option and then reconnecting
23-06-2018 9:15 PM
Moderator's note:
Topic moved from Mobile to My Router as it sounds like a more appropriate board.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
23-06-2018 9:40 PM
Nope. Password correct and checked a dozen times
24-06-2018 8:16 AM
Stupid Boy! Me, that is. The realisation came to me last night just as was falling asleep. I have been entering my Plusnet Login password - not the router password. I'm told it's an age thing and I'm beginning to believe it. maybe the response 'not entering the correct wifi password' triggered something in my subconscious. Anyway, all sorted now. Thanks.
- My Router
