Connecting Ubiquiti AmpliFi HD to Openreach modem
Fredrix
I bought myself an new Ubiquiti AmpliFi router, which is giving me excellent Wifi BUT i can’t get it to work with the Openreach modem. Currently I am connecting it via my old Netgear router.
Does anyme have any experience with this device?
edit:I should say, yes, I have used the (PPPoE, username@plusdsl.net etc) recommended settings
8 REPLIES 8
TheJayBee
Re: Connecting Ubiquiti AmpliFi HD to Openreach modem
I assume you’ve also put in the correct Plusnet password?
Have you connected from LAN1 on the modem to the ‘blue’ socket on your Ubiquiti router?
On the modem, do the Power, DSL and LAN1 lights glow steady green?
What does the port status screen on the router show?
Fredrix
Thank you for your interest. Sorry about the delayed reply. You know, Christmas and all that...
my answers below.
@TheJayBee wrote:
I assume you’ve also put in the correct Plusnet password? YES
Have you connected from LAN1 on the modem to the ‘blue’ socket on your Ubiquiti router? YES
On the modem, do the Power, DSL and LAN1 lights glow steady green? YES except the LAN one, which flickers as it tries (and fails) to make contact with the router
What does the port status screen on the router show? It’s locked to a screen that says “no IP address”
Fixes: 651
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 119
@Fredrix, I'm assuming you have an FTTC/Plusnet Fibre service?
If so, see if you can locate a VLAN ID option in your Internet settings where you've configured the username etc. Enable it and ensure the VLAN ID is configured to 101.
Fixes: 92
@bobpullen I thought the VLAN ID was set in the Openreach modem...
Fixes: 119
Ah yes, you're absolutely right - not personally accustomed to Ubiquiti kit and I overlooked the Openreach modem reference :rolleyes:
Fixes: 92
Unusually, the Ubiquiti does seems as though it may have the ability to set VLAN ID on a PPPoE connection, I'm not sure that many routers do. If that is set then that may be a problem when used with the OR modem. @Fredrix make sure that the VLAN ID is disabled on the Ubiquiti.
Rabh
@frederix can I ask how you resolved this? I’m getting exactly the same issue with my AmplifiHD and openreach modem. I’ve disable vid, using PPoE with the Plusnet username/password which all looks right to me (and worked with previous router. I just get the “No IP address” message.
Any help would be very much appreciated!
