Connected but no internet
Finlee
Hi all,
With our plusnet service everytime you reconnect to the network e.g. My phone connects when I return home from work, it connects to the router but then it says the Internet is unavailable. I then have to select another network (trying to connect to a neighbours signal) and then i have to reselect the plusnet and it connects straightaway to the Internet. It was doing it infrequently when I first joined but now its every single time and its beyond annoying. For some devices it won't even connect, my chromecast has never been switched off, but it's never really been used, and I went to use it the other day I tried to connect to the network and it says I'm connected but there's no Internet. Its just so infuriating.
I've tried searching all weekend for answers but it's difficult to find a result for the above.
Thanks in advance.
Finlee.
9 REPLIES 9
RandallFlagg
Fixes: 75
Re: Connected but no internet
Hi @Finlee
Thanks for getting in touch. I'm sorry to hear that you're experiencing connection issues with our service.
I've reviewed the notes on your account and can see that you've discussed this with one of my colleagues here
Could I ask whether the same issue occurs if you're using our router rather than a 3rd party router?
Best wishes,
Dave
Finlee
Dave, i'm not using a third party router, i'm using the hub plusone (if that's what its called).
I did try and set up my own router to see if I could get the problem to desist without success so i reverted back to the plusnet device.
Can you help?
Finlee
deank
Fixes: 14
Hi @Finlee,
Have you tried forgetting the network on your phone and rebooting the device? It sounds like there is an issue with the configuration on your device. Please try this for me and let me know how it goes.
Finlee
Hi yes I have. This happens on all other tablets/phones connecting to the router.
For example I had to do it with my sons fire tablet last night.
Finlee
Finlee
Anyone?Huh
RandallFlagg
Fixes: 75
Bit of an odd one this, @Finlee
I've arranged for your router to be replaced and for a returns bag to be sent so that you can pop the current one back in the post for us (postage paid).
Could you let us know how you get on when the new router arrives?
Best wishes,
Dave
Finlee
Thanks Dave.
Finlee
Finlee
The new router seems to have done the trick 👍🏻
Fixes: 1,600
Glad to hear that Finlee!
Let us know if you need any further assistance.
