Connect dongle to router
- My Router
- Connect dongle to router
18-12-2020 7:23 PM
Re: Connect dongle to router
23-12-2020 2:47 PM
I don't have one of these so it's a slightly rough answer but I would expect that by some means you configure the Miracast dongle to join the router network (often the device sets up its own WiFi network initially) and then the phone (on the Plusnet router WiFi network) can see the Miracast.
Other than knowing the router WiFi password and the router accepting a connection from the Miracast I don't think the setup needs the Plusnet router to participate.
24-12-2020 10:10 PM
@Quaker Welcome to the forum.
I assune that these work like a Chromcast. The Miracast is plugged into the TV not your router.If the Miracast has both a HDMI and a USB cable the HDMI is used for video and the USB for power. If you do not have a USB socket on the TV then plug it into a mains USB charger. You then connect the Miracast to the router over the wireless link when you set up the App.
