Confuse
rooky
Confuse
I was told earlier you can get 800mb over wifi with the Plusnet router?  Is this true
As I was looking to get a Netgear Orbi mesh ready to set up for full fibre
8 REPLIES 8
Fixes: 254
Re: Confuse
There is the theory (ideal lab conditions) and then there is the real world practicalities!  The Plusnet Hub 2 5GHz specification is MIMO, 802.11a/n/ac
See IEEE 802.11 - Wikipedia for the full specification details - ac on a 20MHz channel will in theory do 693mbps - 40MHz even faster but I'm nots sure that the Hub2 does 40MHz channels, even it if does, it will back off (to be nice) if the spectrum is busy.
Where were you advices that it can sustain 800mbps ... and at what distance from the router?
rooky
Re: Confuse
Someone I know in the village as I was saying to him I was going to buy a orb mesh in stead of using plus net and he said why as the plus net is plenty good enough.
Fixes: 254
Re: Confuse
It certainly is good enough.  Some people will always want more, regardless of their real needs.
Which FTTP service are you on?
rooky
Re: Confuse
900Mb package
Mustrum
Fixes: 81
Re: Confuse
@rooky   The PN Hub 2 is based on the BT Smart Hub which was released in 2016, people on here have reported speeds up to 500Mbps on WiFi.  There are loads of articles and info of the specs if you use your prefered search engine, an example https://www.techadvisor.com/article/717057/bt-smart-hub-review.html .
Whilst you can get higher speeds from WiFi5 routers, you would need the BT Smart Hub2 to get higher speeds from a BT Group router - don't think the EE Smart Hub Plus or Pro - WiFi6 - 7 routers work on PN.
An Orbi or Asus or Lynksys WiFi 6 mesh system will give better performance for a given space.
rooky
Re: Confuse
Thank you
If i get a orbi i dont need the plus net router right as i can connect the orbi straight inti the wall unit ?
Mustrum
Fixes: 81
Re: Confuse
@rooky   correct, but it is always worth getting the ISP router and keeping it in case of faults, support staff will not know much about your own router, and will not be able to get the same diagnostic information if a fault does need checking.
Re: Confuse
@rooky
Although these devices will give higher wireless speeds you could still be restricted by the wireless adaptor of the device being used.
I have a TP-Link router with wifi 6, the HP laptop I use maximum wireless speed is around 300 mbps where as the Pixel 7 pro is around 600 mbps.
