Configuring Plusnet Hub 1 for OpenDNS
sjconnolly
I have used OpenDNS in the past, but I have just upgraded to Fibre. Is there a reasonably straightforward way to configure a Plusnet Hub 1 router to use OpenDNS DNS? Some posts suggest I use Telnet commands, which I am not very familiar with.
4 REPLIES 4
Shep41
Fixes: 6
Re: Configuring Plusnet Hub 1 for OpenDNS
You can't configure the hub 1 to use open dns.
Fixes: 1,473
The firmware is locked down so that DNS servers can't be changed to anything.
You'd have to supply your own modem/router to be able to do this.
Fixes: 1,473
Moderators Note
This topic has been moved from Fibre to My Router
KeithAC
That's a bummer. It means I have to configure every device separately 😞
