Configuring Plusnet Hub 1 for OpenDNS
- My Router
- Re: Configuring Plusnet Hub 1 for OpenDNS
22-10-2019 8:31 PM
I have used OpenDNS in the past, but I have just upgraded to Fibre. Is there a reasonably straightforward way to configure a Plusnet Hub 1 router to use OpenDNS DNS? Some posts suggest I use Telnet commands, which I am not very familiar with.
22-10-2019 9:07 PM
22-10-2019 9:11 PM
The firmware is locked down so that DNS servers can't be changed to anything.
You'd have to supply your own modem/router to be able to do this.
22-10-2019 9:12 PM
Moderators Note
This topic has been moved from Fibre to My Router
22-03-2020 2:40 PM
That's a bummer. It means I have to configure every device separately 😞
- My Router
