Computer won’t connect to wireless.
- My Router
- Computer won’t connect to wireless.
04-02-2021 10:21 AM
Please someone help this is so frustrating as I’m having to use my phones 4g to connect the pc online and obviously this isn’t ideal.
Regards, Ryan.
Re: Computer won’t connect to wireless.
04-02-2021 11:54 AM
Try the following from another of my post. https://community.plus.net/t5/My-Router/Wifi-disconnection-issues/m-p/1790797#M24171
04-02-2021 3:08 PM
“Point web browser to 192.168.1.254.”
I try this and no webpage loads up
04-02-2021 4:15 PM
Open your browser and enter 192.168.1.254 in the address field. Not the search field if you have one. Assuming of course that you are using a Plusnet hub.
04-02-2021 8:07 PM
04-02-2021 8:08 PM
04-02-2021 11:44 PM
You’ll need a good connection to your router to be able to access the settings in the router.
As its the wireless you’re trying to fix and that’s not a good connection you may have to plug a laptop or computer into the router using an Ethernet cable
05-02-2021 10:07 AM
To expand on @Thrall ‘s post. To split the bands you don’t need the hub connected to the DSL socket so you can unplug it from where it is located and move it to your PC to use the supplied Ethernet cable. You can also check whether it will connect wirelessly before moving it back to the BT Master socket.
05-02-2021 10:11 AM
11-02-2021 3:35 PM
- My Router
