Cisco Expert needed 887VA plusnt fibre
- My Router
- Cisco Expert needed 887VA plusnt fibre
20-07-2017 1:17 AM
Hello,
So i wanted to setup a 887va router i had spare (to setup a site to site VPN connection for work)
i can get it connected so the VDSL LIGHT is on and the data light flashes, it even gives the correct external static ip address.
But i cannot access the internet , config below, i would be very grateful!
Re: Cisco Expert needed 887VA plusnt fibre
20-07-2017 8:58 AM
Try this config, I think it will work. You need to change the *YourUsername* and *YourPassword* to yours.
Connect the phone line to the router using the RJ11 and Ethernet3 to your network.
Try this:
i
ip cef
no ipv6 cef
username *-* privilege 15 password 0 *-*
controller VDSL 0
no cdp run
interface Ethernet0
no ip address
ip virtual-reassembly in
no ip route-cache
interface Ethernet0.101
description Tagging for PPPoE (VDSL 0)
encapsulation dot1Q 101
ip nat outside
no ip route-cache
pppoe enable group global
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
no ip address
shutdown
no cdp enable
interface FastEthernet1
no ip address
shutdown
no cdp enable
interface FastEthernet2
no ip address
shutdown
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface Vlan1
ip address 10.80.2.252 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip route-cache policy
interface Dialer1
description **Plus Net**
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication pap chap ms-chap callin
ppp chap hostname *YourUsername*@plusdsl.net
ppp chap password 0 *YourPassword*
ppp ipcp dns request accept
ppp ipcp route default
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
access-list 1 permit any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
password *YourPassword*
login local
transport input telnet ssh
end
20-07-2017 4:50 PM
I didn't have much time this morning, so I just posted a full config so that you could compare yours with the one I posted.
First you need to get rid of interface dialer0 as you are using dialer1 for VDSL. You've shut down the atm0 interface which is for ADSL so that looks right.
The Vlan 101 sub interface on Ethernet0 (Which is the VDSL modem) needs a little bit more config to make it work.
You need to add: ip nat outside to tell the router that its WAN side, also add the following:
no ip route-cache
Vlan1 is the default Vlan for the Ethernet switch built into the router and this looks OK.
Also on dialer1 I think the MTU sizes are incorrect:
ip mtu 1492
05-01-2018 2:15 PM
@andydis Did the config that Mike suggested work for you? I plan to give it a try later on tonight as I have switched from ADSL to VDSL and want to amend our Cisco router config to suit.
06-01-2018 11:34 AM
@imi Which model of Cisco Router are you using?
The reason I ask is that some of the older 800 series can only cope with about 30 M/bits of throughput with a very light config (i.e. no ip packet inspection).
Also have you taken a TV package from Plusnet? If so, then the config I posted doesn't support IPTV.
- My Router
