Changing to fibre and using existing BT Hub 6
- My Router
- Changing to fibre and using existing BT Hub 6
21-10-2019 1:04 PM
Can I use my existing BT Hub 6, or do I need to use Hub one/ and will I need to change anything on BT Hub 6 if I can use it
Message 1 of 4
(514 Views)
3 REPLIES 3
Re: Changing to fibre and using existing BT Hub 6
21-10-2019 1:35 PM
Yes you can use the hub 6 . You will just need to change the loggin details to match the PLUSNET account. There are numerous threads on here explaining how this is done.
Message 2 of 4
(497 Views)
21-10-2019 1:41 PM
Sorry I should have said that I am already on PN.
Thanks for your help
Message 3 of 4
(491 Views)
21-10-2019 4:57 PM
Hi @Toby1971
As long as the Hub you are using is VDSL compatible (which i believe the HH6 is) then as @Shep42 said, as long as you have the correct auth credentials inside it, you should be fine.
Kind Regards,
Alisdair
Message 4 of 4
(461 Views)
- My Router
