Changing router and modem
Newt007
Hi need help
I have bought a new router modem
Netgear AC1600 wifi vdsl/ Adsl2+ modem router to replace my openreach and plusnet router can this be done with a simple switch over or is it more complicated
Thanks .Newt
3 REPLIES 3
Fixes: 1,485
Re: Changing router and modem
Moderators Note
This topic has been moved from Chat to My Router
daveplus
Fixes: 10
The Netgear manual will tell you how to set it up.  Your Plusnet account specific settings etc won't change.
Dave
Fixes: 421
@Newt007
If you need to configure it manually the settings are here  https://www.plus.net/help/broadband/broadband-connection-settings/
