Changing router and modem
- My Router
- Changing router and modem
13-04-2020 3:46 PM
Hi need help
I have bought a new router modem
Netgear AC1600 wifi vdsl/ Adsl2+ modem router to replace my openreach and plusnet router can this be done with a simple switch over or is it more complicated
Thanks .Newt
Thanks .Newt
Message 1 of 4
(2,508 Views)
3 REPLIES 3
Re: Changing router and modem
13-04-2020 3:48 PM
Moderators Note
This topic has been moved from Chat to My Router
13-04-2020 4:14 PM
The Netgear manual will tell you how to set it up. Your Plusnet account specific settings etc won't change.
Dave
13-04-2020 4:27 PM
If you need to configure it manually the settings are here https://www.plus.net/help/broadband/broadband-connection-settings/
