Changing IP Address range on router
- My Router
- Changing IP Address range on router
02-11-2018 10:08 AM
Got my fibre upgrade. Got my router. It connected straight away (which for an old network hand this is a bit creepy!)
Anyway, my LAN runs on 10.0.0.0/24, always has and always will. However the Plusnet Hub One tells me this is an invalid entry.
So I have two questions.
1. How do I change it?
2. Is this a managed hub? ie. Do Plusnet gain access to my LAN through this Hub? If so, it will need to be firewalled, the ISP ends at the BT master socket in my house.
Note: I found another very similar thread but that user choose to change his LAN to suit the Hub. I don't want to do that.
Thanks,
Paul
Re: Changing IP Address range on router
02-11-2018 10:14 AM
Getting another vdsl modem/router is likely to be the only solution.
02-11-2018 10:15 AM
Moved from Fibre to My Router
02-11-2018 10:17 AM
Okay. And as a rebadged BT hub it's a Trojan device with LAN access.
Thus I can solve both my problems by putting it behind a firewall/router which will translate the IP address range with NAT.
02-11-2018 11:44 AM
Why not just ditch the Hub One and use one that suits your requirements? Settings required are here https://www.plus.net/help/broadband/broadband-connection-settings/
- My Router
