Changed password causing router problems!
- My Router
- Re: Changed password causing router problems!
โ25-10-2016 7:35 AM
I have a Tplink TD-W8961ND and I'm pulling what's left of my hair out trying to change it following their online guide but I've still no success. Can someone please help me out?
โ25-10-2016 8:09 AM - edited โ25-10-2016 8:11 AM
As it is not a Plusnet supplied router there is no on-line guide. From a quick search this is probably shows you where you need to be looking:
https://www.manualslib.com/manual/358686/Tp-Link-Td-W8961nd.html?page=25#manual
I'd expect the username on that page to be yourplusnetusername@plusdsl.net
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (ยฃ14.40/month) Mobile: iD mobile (ยฃ4/month) |
โ25-10-2016 9:50 AM
The link @jelv provided should help you get this sorted. If I remember correctly the address to go to in your browser is 192.168.1.1 and then log in using your router's credentials.
โ25-10-2016 2:51 PM
โ25-10-2016 3:00 PM
- My Router
