Changed SSID Now I have two WIFI?
- My Router
- Changed SSID Now I have two WIFI?
17-06-2018 7:44 PM
I changed my SSID and now I have two WIFI signals I can connect to. One with my new SSID and the other is XYZ_80.
I did a factory reset and it's still available to sign into?
Anyone got any ideas?
Re: Changed SSID Now I have two WIFI?
17-06-2018 10:49 PM
If its a Hub One and the bands aren't synchronised then one is on the 2.4GHz band and the other 5GHz
18-06-2018 8:30 AM
Hi Baldrick, thanks for the reply.
Yes, it's a Hub One. How do you synchronise them? Simple?
18-06-2018 9:17 AM
Yep should be.
Have a look at the last post in this thread which should show you.
18-06-2018 11:35 AM
It will cause you a lot less hassle if you leave them unsynchronised
- My Router
