Change router default domain name from "lan"
- My Router
- Re: Change router default domain name from "lan"
23-08-2019 7:31 PM - edited 23-08-2019 7:31 PM
Hi
can I / how can I change the router (dhcp supplied) default domain name from "lan" ?
regards
Richard J
01-09-2019 3:09 PM
01-09-2019 8:49 PM
Hi
I have a
01-09-2019 9:51 PM
Hi Rich, thanks for getting back to me.
I’ve had a quick look and it doesn’t look like there’s an option to in the advanced settings of the router. Having said that by domain name, are you referring to the router address because that should be 192.168.1.254?
- My Router
