Change network key
FIXED- Subscribe to RSS Feed
- My Router
- Change network key
29-10-2018 11:04 AM
In Settings I only found a way of changing the Admin password
Fixed! Go to the fix.
Re: How to change my network key
29-10-2018 12:28 PM
29-10-2018 12:38 PM
I suspect the OP is trying to change the wireless key.
We do need to know make and model of router, but if its a plusnet hub 1.....(Bt home hub 5 or 6)
Login to the router at 192.168.1.254
Browse to wireless under advanced settings, after putting in your admin password.
you should then see an option to change your wireless key (and also to split the 2.5Ghz and 5Ghz frequencies)
29-10-2018 12:44 PM
The guide to all the current Plusnet supplied routers is available at https://www.plus.net/help/broadband/router-user-guides/ which includes instructions and videos on how to taken the WiFi password (among other things).
29-10-2018 12:57 PM
Moderator's note:
Topics merged into 'My Router' board.
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
29-10-2018 1:23 PM
Many thanks penfold
