Change my wireless key
GH68
Hello any advice on how to change my wireless key please. I’ve looked through the forum but seem to be going round in circles Any help appreciated
5 REPLIES 5
Fixes: 480
Re: Change my wireless key
Moderator's note:
Thread moved from Broadband to My Router.
Gel
Champion
Fixes: 29
Fixes: 383
@GH68 Which router?
GH68
Not sure. Where do I find out. Has a circle on the front only had it 6 months
Fixes: 383
OK, most probably a Hub2 then. I unfortunately have never had one of those, so am not familiar with them, but if you log into the Hub, and go from Home>Advanced settings>wireless, does that screen give you any options?
