Change device names in admin. Doesnanyone know how to customise the random device names
DWilliams2000
Does anyone know how to change the random device names generated in the admin profile so that you can easily select different devices to add to the acces schedule in admin page please.
3 REPLIES 3
Re: Change device names in admin. Doesnanyone know how to customise the random device names
Hi @DWilliams2000 welcome to the forum.
Are you referring to device names in my network on your Hub? If so which one are you using?
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Router
DafOwen
If change the name of connected device - you need to click the "Change Settings" button onthe top before it allows you to update.
Note: Pic attached - for Hub Two
