Cant set up BT hub 6 ....help
- My Router
- Cant set up BT hub 6 ....help
07-07-2020 1:24 PM
Re: Cant set up BT hub 6 ....help
07-07-2020 1:55 PM
@Jowser Welcome to the forum
I assume that you have followed the instructions here to the letter https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
Some firmware versions do not like special characters in your Plusnet password. Do you have any in your Plusnet password? If so go into your Plusnet account and change it to only alpha numeric ones. Ignore the Plusnet advice to use these special characters.
07-07-2020 2:04 PM
07-07-2020 2:15 PM
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 86.0 (64-bit)
08-07-2020 6:50 AM
08-07-2020 10:55 AM
Is it remembering your Plusnet username and password or is it reverting to the BT one?
- My Router
