Cannot port forward Call Of duty Modern Warefare 2
Aldabbagha
I am facing a problem when I trying to port forward Call Of duty Modern Warfare 2 multiplayer so my friends can join my private game. The port is 28960 and no matter what I do, nothing works. I have restarted the router multiple times, tried assigning different IP addresses to my PC even restarting my PC. I have allowed the game through the windows firewall and have enabled UPnP on the router.
Can someone please help?
9 REPLIES 9
Fixes: 1,483
Re: Cannot port forward Call Of duty Modern Warefare 2
Have you actually forwarded the port?
UPnP won’t do that for you.
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Aldabbagha
Yes I have.
Aldabbagha
any help?
Fixes: 1,483
Can you connect to your pc locally?
Have you tried a port checker to see if the port is open?
Have you turned of the PN firewall?
Aldabbagha
1. What do you mean?
2. of course not opened
3. yes and has not worked
Fixes: 1,483
1) Have you tried connecting from within your local network rather than via the internet. Helps show whether the issue is on your pc or the router
Aldabbagha
I cannot try it because the game is on my PC I don't have any other PCs that have the game installed..
Fixes: 419
Did you turn off the Hub firewall? Have you checked the account firewall settings?  https://www.plus.net/help/broadband/about-plusnets-broadband-firewall/
