Cannot login to TG582n Router
- My Router
- Re: Cannot login to TG582n Router
19-12-2016 4:38 PM
Can't login to router as admin.
User name admin, password serial does not work, tried variations, Administrator etc.. but no luck. Factory reset no change.
Anyone have any ideas?
19-12-2016 4:46 PM
Welcome to the community forums @uncoolsam
Apologies if this sounds like an obvious question, but when entering the password, did you enter all the letters in uppercase?
If you haven't already, please could you also try logging in to the router from another device and if possible via a wired connection to see if the same problem is apparent across other devices.
Thanks.
19-12-2016 4:48 PM
Yes, all uppercase. Have tried from different devices.
19-12-2016 5:30 PM
20-12-2016 12:03 PM
- My Router
