Cannot Find WPS PIN entry Plusnet Hub One
- My Router
- Cannot Find WPS PIN entry Plusnet Hub One
25-02-2020 11:07 PM
I am trying to connect my wireless printer to my Plusnet Hub One, I have followed the instructions, printed the WPS PIN number but then it says to open the router configuration and enter the PIN. This option is nowhere to be found. Can anyone help?
Re: Cannot Find WPS PIN entry Plusnet Hub One
26-02-2020 8:21 AM
Moderators Note
This topic has been moved from Fibre to My Router
26-02-2020 11:40 AM
This is a new one on me. The two methods that I am familiat with is either to set the printer searching for connections and pressing the WPS button on the hub or alternatively selecting the router SSID on the printer display then entering the wireless password into the printer.
What printer do you have?
on
18-05-2020
2:03 PM
- last edited on
18-05-2020
2:18 PM
by
Strat
Envy photo 6220 been running WPS now for 20 mins.
Moderator's note by Dick (Strat): All caps title/text edited as per Forum rules.
- My Router
