Can anyone recommend a Wifi extender for the Hub 1?
- My Router
- Re: Can anyone recommend a Wifi extender for the H...
08-07-2020 2:53 PM
Hi all.
As the thread title states, is there a decent, cheap Wi-Fi extender for the Hub 1?
Thanks.
Thanks.
Message 1 of 2
(433 Views)
1 REPLY 1
Re: Can anyone recommend a Wifi extender for the Hub 1?
08-07-2020 5:09 PM
A few years ago I bought a BT branded extender as I was keen to ensure no compatability issues (the HUB 1 is a rebranded BT Hub 5 as you are probably aware). It has worked fine.
The model I got was called the WI-Fi Extender 300 and was, if I recall, towards the bottom of the BT range of extenders. That model is almost certainly no longer available but there will be others on the market now.
Message 2 of 2
(408 Views)
- My Router
