Can U use Plusnet full fiber without the Plusnet Hub and direct connect mt Deco X55?
AKWatson
Hello All
     Im currently a Sky broadband customer and due to their router config (DHCP Option 61) you can connect a Deco x55 direct to the BT Openreach ONT.
BT broadband can do this so wanted to see if Plusnet did - im about to move providers as im committed to the Deco x55 Network and Plusnet if that works will be where I move to.
Can anyone confirm please?
4 REPLIES 4
Fixes: 580
Re: Can U use Plusnet full fiber without the Plusnet Hub and direct connect mt Deco X55?
@AKWatson as long as the Deco supports PPPoE for its internet connection, then it can be used with Plusnet.
Given that BT broadband also uses PPPoE , it shouldn't be a problem.
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Router
thackie2015
I use deco m5 mesh system and it works fine with Plusnet.
as mentioned previous set as PPoE then Plusnet credentials.
Eggs
Sorry to be pedantic but it is spelt "fibre".
