Can Plus.Net remote reboot my router?
Scorpuk
I am unable to remote connect to my router and was wondering if it is possible for Plus.Net to remote reboot it?
5 REPLIES 5
Anotherone
Champion
Fixes: 21
Re: Can Plus.Net remote reboot my router?
I'm not sure if they can do it directly, but I know a man that would likely know @bobpullen  I can think of a crafty way of doing it and I assume it's a Plusnet modem/router otherwise I'd guess the answer would be no.
Fixes: 1,481
Assuming the connection hasn't gone down of course..
Anotherone
Champion
Fixes: 21
This is of course true and maybe the reason the OP can't access it, but then the 'man that can' would be able to discover that and at least raise a fault on the OP's behalf Wink
bobpullen
Fixes: 315
Do you still need this doing? Are you just wanting the connection restarting or is there some reason you need the router itself physically rebooting?
Chris
Legend
Fixes: 169
We can easily remotely kick a connection, which generally would reconnect.
