Can I use two hubs with one broadband
diomingyuli
Sometines connection gets weak in some rooms so I wonder if I can set another router in the house to boost the connection. Any idea?
3 REPLIES 3
Fixes: 1,483
Re: Can I use two hubs with one broadband
Moderators Note
This topic has been moved from Fibre to My Router
paul_blitz
Only one hub can be used to connect to the internet connection (= your phone line).
I suspect your question is about wifi, or rather a lack of it in parts of your house. There are 2 solutions:
1) use an ethernet cable to add a Wireless Access Point (if you are technical, then you might be able to use an old router to do this)
2) Use a "Wireless Extender"... this connects to your current wifi, then 'rebroadcasts' it further into your house.
Fixes: 417
@diomingyuli
This might help explaining your options.  https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Distributing-Data-around-Larger-Proper...
