Can I use the hub one on adsl broadband?
Antonyb
Hello everyone I’m sorry if this question has been asked before but  I recently bought plusnet broadband adsl 10mb fibre doesn’t exists in my area unfortunately  and last time I joined a few years ago I got given the hub zero the basic router ? Would it be possible to get the hub one and use it on standard broadband?  As I feel the hub zero is abit sub standard if the answer is no do I have any alternatives?
8 REPLIES 8
Legend
Fixes: 254
Re: Can I use the hub one on adsl broadband?
Welcome to the forums, @Antonyb . You won't get a new router from PN if you have just signed up - the HubZero is the 'free' one for ADSL connections. A suggestion made frequently on the forums is to spend around £20/£25 on a BT HH6 from that well-known auction site and use that. Configuration/set-up details are on the My Router board.
Antonyb
Thank you for your reply will that work even on non fibre broadband?
Legend
Fixes: 254
The HH6 works on both ADSL and FTTC, otherwise I wouldn't have suggested it.
Antonyb
Alright no worries I’ll see if I can find one at a reasonable price then cheers
Antonyb
I’ve just managed to get a preowned one for £8 which I think is a fairly decent deal
Legend
Fixes: 254
@Antonyb That's a really good deal. All you have to do now is set it up.👍
Antonyb
Thanks a lot for your help really appreciate it I was going to buy an open never used one but with delivery there around £30+ so I managed to get a cheap used one.
Fixes: 418
@Antonyb
The setting instructions are here. Note that you must not plug in the DSL cable until after you have entered your Plusnet User Name and Password, as per the instructions.  https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
